[MapServer-dev] Documentation of the config file
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Wed Oct 25 09:03:23 PDT 2023
Config file is documented under mapfile at https://mapserver.org/mapfile/config.html. Isn't that a wrong place because this CONFIG is not a part of a mapfile? And maybe it could be documented as "config file" or something that is clearly different than the CONFIG under mapfile/MAP https://mapserver.org/mapfile/map.html even those two can serve some common purposes. BTW does the mapfile win if the same ENV is set both in the config file and in the mapfile?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20231025/96144b40/attachment-0001.htm>
More information about the MapServer-dev
