[MapServer-dev] RFC 138 - Reference SLD files in Mapfiles
Seth G
sethg at geographika.co.uk
Mon Feb 12 12:47:43 PST 2024
Hi Jukka,
Yes, I'll update to say "any new concerns".
That particular issue though I believe has already been addressed through external graphics validation added in MapServer 7.0 - see https://mapserver.org/MIGRATION_GUIDE.html#mapserver-6-4-to-7-0-migration
WEB
VALIDATION
"sld_external_graphic" "^.*/sld/data/.*"
END
See also the discussion in https://mapserver.org/development/rfc/ms-rfc-124.html
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Mon, Feb 12, 2024, at 9:21 PM, Rahkonen Jukka wrote:
> Hi,
> The paragraph about security concerns says "MapServer already accepts
> SLD from remote URLs and client requests, so local SLD files shouldn't
> cause any concerns."
> It could be "shouldn't cause any new concerns". We may already have
> some, for example when the SLD contains external graphics.
> <sld:ExternalGraphic>
> <sld:OnlineResource
> xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
> xlink:href="http://127.0.0.1/svg2.svg" />
> <sld:Format>image/svg</sld:Format>
> </sld:ExternalGraphic>
> I think I have heard that this can be used for XXE injections.
> Geoserver has nowadays a configuration option for defining a whitelist
> https://docs.geoserver.org/stable/en/user/production/config.html#external-entities-resolution
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org>
> Puolesta Seth G via MapServer-dev
> Lähetetty: lauantai 10. helmikuuta 2024 1.04
> Vastaanottaja: MapServer Devs <mapserver-dev at lists.osgeo.org>
> Aihe: [MapServer-dev] RFC 138 - Reference SLD files in Mapfiles
> Hi all,
> I've added a new RFC - MS RFC 138: Reference SLD files in Mapfiles at
> https://mapserver.org/development/rfc/ms-rfc-138.html
> This would allow SLD files to be referenced in a Mapfile using the
> STYLEITEM (similar to how JS files are referenced):
> LAYER
> STYLEITEM "sld://mysldfile.xml" # uses SHAPEPATH and if not set
> then relative path to the Mapfile or absolute path
> CLASS # define an empty CLASS here
> END
> END
> It will make it easier to export Mapfiles from other application such
> as QGIS, and to share styles e.g. between MapServer and GeoServer. More
> details are in the RFC.
> Feedback and comments appreciated.
> I'll start with my +1,
> Seth
> web:https://geographika.net/ & https://mapserverstudio.net/
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev
