[MapServer-dev] GNU Regex Replacement?
Even Rouault
even.rouault at spatialys.com
Sat Jun 8 06:35:49 PDT 2024
my attempt at https://github.com/MapServer/MapServer/pull/7073 . It
links, but PCRE2 doesn't seem to speak the same regex dialect as GNU
regex...
Even
Le 08/06/2024 à 05:31, Paul Ramsey via MapServer-dev a écrit :
> Looks like it was in Centos as far back as 7, and is in base Ubuntu.
> It’s in MacPorts and Homebrew. So, fairly common?
> P.
>> On Jun 7, 2024, at 8:06 PM, Steve Lime <sdlime at gmail.com> wrote:
>> One would think replacement wouldn’t be that hard. It’s pretty
>> localized in MapServer. Is pcre2 widely available?
>> On Fri, Jun 7, 2024 at 2:40 PM Paul Ramsey via MapServer-dev
>> <mapserver-dev at lists.osgeo.org> wrote:
>> We dragged around a dependency on pcre which got updated to pcre2
>> lately.
>> > On Jun 7, 2024, at 12:38 PM, Howard Butler via MapServer-dev
>> > I was playing around with getting Conda Forge builds of
>> MapServer working, and when I got to Windows, I realized we need
>> the GNU Regex library
>> https://github.com/conda-forge/mapserver-feedstock/issues/47#issue-2341018003
>> > It is ancient, not released as a standalone library anymore,
>> and causes anything linking against it to also be GPL (which
>> we're doing in the Windows build situation). Maybe it is not
>> worth the trouble to change anything, but if one were to do so,
>> what should be used in its place?
>> > Howard
>> > _______________________________________________
>> > MapServer-dev mailing list
>> > MapServer-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20240608/9a8aedeb/attachment-0001.htm>
More information about the MapServer-dev
