[MapServer-dev] GNU Regex Replacement?
Even Rouault even.rouault at spatialys.com
Sat Jun 8 08:36:58 PDT 2024
UPDATE: msautotest now pass against PCRE2 with a few extra fixes.
This was actually quite helpful to uncover 2 underlying issues, not
related to PCRE2 itself:
- one (likely) wrong default regex with ms_map_bad_pattern_default in
msCGILoadMap() where escaping antislash was missing (probably tolerated
by GNU regex , but PCRE2 is more picky about that). Easy to fix
- and more embarrassing, our redefined MS_REG_xxxx constants in
mapregex.h happen to not match the values of GNU regex (they might
perhaps have matched in earlier times, but things have drifted apart
since then)... In particular, MS_REG_NOSUB = 4 was thus wrongly
interpreted as REG_NEWLINE = (1 << 2). I loose some extra hair on
figuring that out. The symptom was in rfc62.map where a query string
parameter whose value is "foo%0Abar" (foo newline bar) happened to
validate (with GNU regex) the following expression '^[a-z]{1,16}$'
whereas it shouldn't have (our expected result was incorrect). The value
matched because msEvalRegex() sets MS_REG_NOSUB which was wrongly
interpreted as REG_NEWLINE, thus making the caret / dollar to apparently
match any line instead of the whole string. When using PCRE2, the match
didn't occur because PCRE2 and GNU regex have exactly subtle different
semantics regarding newline matching (I tried to understand
https://www.pcre.org/current/doc/html/pcre2posix.html#SEC5, but beyond
my mastering)
So all in all, it seems PCRE2 could be a viable alternative. I would
expect "subtle" differences, so any mapfile having regular expressions
in it that was tested with GNU/BSD/POSIX/whatever regex should be
carefully checked for correct execution if switching to PCRE2
Even
Le 08/06/2024 à 15:35, Even Rouault via MapServer-dev a écrit :
> Hi,
> my attempt at https://github.com/MapServer/MapServer/pull/7073 . It
> links, but PCRE2 doesn't seem to speak the same regex dialect as GNU
> regex...
> Even
> Le 08/06/2024 à 05:31, Paul Ramsey via MapServer-dev a écrit :
>> Looks like it was in Centos as far back as 7, and is in base Ubuntu.
>> It’s in MacPorts and Homebrew. So, fairly common?
>> P.
>>> On Jun 7, 2024, at 8:06 PM, Steve Lime <sdlime at gmail.com> wrote:
>>> One would think replacement wouldn’t be that hard. It’s pretty
>>> localized in MapServer. Is pcre2 widely available?
>>> On Fri, Jun 7, 2024 at 2:40 PM Paul Ramsey via MapServer-dev
>>> <mapserver-dev at lists.osgeo.org> wrote:
>>>     We dragged around a dependency on pcre which got updated to
>>>     pcre2 lately.
>>>     > On Jun 7, 2024, at 12:38 PM, Howard Butler via MapServer-dev
>>>     > I was playing around with getting Conda Forge builds of
>>>     MapServer working, and when I got to Windows, I realized we need
>>>     the GNU Regex library
>>>     https://github.com/conda-forge/mapserver-feedstock/issues/47#issue-2341018003
>>>     > It is ancient, not released as a standalone library anymore,
>>>     and causes anything linking against it to also be GPL (which
>>>     we're doing in the Windows build situation). Maybe it is not
>>>     worth the trouble to change anything, but if one were to do so,
>>>     what should be used in its place?
>>>     > Howard
>>>     > _______________________________________________
>>>     > MapServer-dev mailing list
>>>     > MapServer-dev at lists.osgeo.org
>>>     > https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20240608/d0a01a42/attachment.htm>
More information about the MapServer-dev mailing list
