[MapServer-dev] PHP mapscript-ng problem using map->setLayersDrawingOrder()
Worth Lutz
wal3 at mindspring.com
Tue Sep 24 04:20:01 PDT 2024
Hi All,
I'm trying to do an upgrade to MapServer v8 and Mapscript-ng. I'm unable
to get $map->setLayersDrawingOrder($layerOrderArrayOfIntegers) to work.
I get this error:
Expected SWIGTYPE_p_int for argument 2 of mapObj_setLayersDrawingOrder
I'm assuming it is because of this note in the documentation:
Note Unless the proper typemap is implemented for the module’s
language users will not be able to pass arrays or lists to this method
and it will be unusable.
I spent yesterday looking at SWIG and typemaps but as I do not use C I
did not understand what I was reading.
Is there anything I can do to use setLayersDrawingOrder in my code?
Thanks,
*Worth Lutz*
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20240924/6367bdfa/attachment.htm>
More information about the MapServer-dev
