[MapServer-dev] ogcapi.cpp 404 on https://raw.githubusercontent.com/opengeospatial/ogcapi-processes/master/core/openapi/schemas/exception.yaml
    Jeff McKenna
    jmckenna at gatewaygeomatics.com
    Tue Apr 15 03:35:08 PDT 2025
Hi Willem, yes please file the issue there, I will fix it in the source
now.  thanks, -jeff
On 2025-04-15 7:30 a.m., Willem Jenniskens via MapServer-dev wrote:
> Thanks,  I am not really familiar with open source development. But I
> think this should be fixed in the source on github, right?
> Should I create an 'issue' on https://github.com/MapServer/MapServer/
> issues <https://github.com/MapServer/MapServer/issues> or something else?
> *Van:* MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> namens
> Gérald Fenoy via MapServer-dev <mapserver-dev at lists.osgeo.org>
> *Verzonden:* dinsdag 15 april 2025 10:57
> *Aan:* Sebastiaan Couwenberg <sebastic at xs4all.nl>
> *CC:* mapserver-dev at lists.osgeo.org <mapserver-dev at lists.osgeo.org>
> *Onderwerp:* Re: [MapServer-dev] ogcapi.cpp 404 on https://
> Hi,
> You can also use the official schemas directory below:
> https://schemas.opengis.net/ogcapi/common/part1/1.0/openapi/schemas/
> exception.yaml <https://schemas.opengis.net/ogcapi/common/part1/1.0/
> openapi/schemas/exception.yaml>
> Best regards
> Gérald Fenoy
>> Le 15 avr. 2025 à 10:35, Sebastiaan Couwenberg via MapServer-dev <mapserver-dev at lists.osgeo.org> a écrit :
>> On 4/15/25 9:06 AM, Willem Jenniskens via MapServer-dev wrote:
>>> In mapogcapi.cpp this url is present:
> master/core/openapi/schemas/exception.yaml <https://
>>> It gives 404. I think it should be:
> master/openapi/schemas/common-core/exception.yaml <https://
> openapi/schemas/common-core/exception.yaml>
>>> or
>>> https://raw.githubusercontent.com/opengeospatial/ogcapi-processes/refs/
> heads/master/openapi/schemas/common-core/exception.yaml <https://
> raw.githubusercontent.com/opengeospatial/ogcapi-processes/refs/heads/
> master/openapi/schemas/common-core/exception.yaml>
>>> Do you agree? What is the best way to do this?
>> Using one of the tags should be a more stable ref than master, e.g.:
> tags/1.0-draft.6/core/openapi/schemas/exception.yaml <https://
> raw.githubusercontent.com/opengeospatial/ogcapi-processes/refs/tags/1.0-
> draft.6/core/openapi/schemas/exception.yaml>
>> A specific commit should also be stable:
> processes/6f4945ed158fa064bb75a0f11d24c8f683f2fb6b/core/openapi/schemas/
> exception.yaml <https://raw.githubusercontent.com/opengeospatial/ogcapi-
> exception.yaml>
>> Kind Regards,
>> Bas
>> GPG Key ID: 4096R/6750F10AE88D4AF1
>> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev <https://
> lists.osgeo.org/mailman/listinfo/mapserver-dev>
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-dev
