[MapServer-dev] RFC-140 - MapServer Homepage
Seth G
sethg at geographika.co.uk
Sat Jan 18 14:39:21 PST 2025
Looking again at the landing page JSON at https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi?f=json it is in the same format, so as you suggested could simply be expanded with links to WxS services, or even CGI generated responses. This would also more easily allow template reuse.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Sat, Jan 18, 2025, at 11:33 PM, Seth G via MapServer-dev wrote:
> Hi Even,
> Thanks for your valuable feedback.
> The homepage would be a "superset" of all available Mapfiles in a
> MapServer deployment, as listed in the CONFIG file. Each individual
> Mapfile would still have its own OGC API landing page, so the homepage
> is best described as a directory of all landing pages.
> As most MapServer deployments will likely be serving out a combination
> of WxS and new OGC API services for some time to come, it will allow
> both types to be listed together (I'm unaware of a OGC API spec that
> would cover this).
> In regard to the JSON used for links, I was modelling it as closely as
> possible to OGC API conventions. Looking at the pygeoapi demo home
> page, it provides a set of links in a common format, so I'll likely
> switch to this format/approach:
> https://demo.pygeoapi.io/stable?f=json
> A few of the "rel" values are defined as below, and can be reused:
> alternate Provides an alternate representation (e.g., HTML version of a
> resource).
> service-desc Links to the machine-readable API description (e.g.,
> OpenAPI JSON).
> service-doc Links to the human-readable API documentation (e.g.,
> OpenAPI HTML).
> conformance Lists the standards and conformance classes supported by
> the API.
> I'll update the RFC with the above,
> Seth
> On Sat, Jan 18, 2025, at 12:39 PM, Even Rouault wrote:
>> Seth,
>> Thanks for putting this together. I'm wondering how much your proposal
>> relates/intersects with the concept of the landing page of OGC API
>> services ? You mention some connection with it, but it is not
>> immediately clear to me the exact nature of the connection. Perhaps it
>> is just a matter of clarifying. I have put zero thoughts in it, but it
>> would feel weird to invent a MapServer specific thing, so I'm naively
>> wondering if we can't we just adopt the landing page formalism (for the
>> JSON part), and potentially extend it by exposing old WxS services as
>> well in the links as you suggest? I'm also wondering if there's some
>> best practice used by other projects on how to expose for things like
>> "href":
>> "https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities",
>> "title": "GetCapabilities",
>> "type": "WMS"
>> so they can be interoperably consumed.
>> Even
>> Le 18/01/2025 à 09:11, Seth G via MapServer-dev a écrit :
>>> Hi devs,
>>> I've drafted an RFC with an approach of creating a MapServer homepage based on the MAPs referenced in a mapserver.conf file. This will allow MapServer installations to easily advertise available services, dynamically.
>>> Text available in pull request at https://github.com/MapServer/MapServer-documentation/pull/996
>>> Comments and thoughts appreciated,
>>> Thanks,
>>> Seth
>>> MapServer-dev mailing list
>>> MapServer-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> Butcher of all kinds of standards, open or closed formats. At the end,
>> this is just about bytes.
More information about the MapServer-dev
