[MapServer-dev] RFC-140 - MapServer Homepage
Tom Kralidis
tomkralidis at gmail.com
Sun Jan 19 08:10:14 PST 2025
Seth: thanks for this RFC. IETF has api-catalog (draft, [1]) which I
think would be a good candidate for this RFC. This is also an item for
review in the OGC API - Records SWG [2].
Overall it looks pretty close to the RFC proposal. We can consider using
api-catalog as a baseline and we can extend the JSON accordingly as needed
for anything specific to our needs.
Cheers
..Tom
[1] https://datatracker.ietf.org/doc/draft-ietf-httpapi-api-catalog
[2] https://github.com/opengeospatial/ogcapi-records/issues/355
On Sat, Jan 18, 2025 at 5:39 PM Seth G via MapServer-dev <
mapserver-dev at lists.osgeo.org> wrote:
> Looking again at the landing page JSON at
> https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi?f=json it is
> in the same format, so as you suggested could simply be expanded with links
> to WxS services, or even CGI generated responses. This would also more
> easily allow template reuse.
> Seth
> web:https://geographika.net & https://mapserverstudio.net
> mastodon: @geographika at mastodon.social
> On Sat, Jan 18, 2025, at 11:33 PM, Seth G via MapServer-dev wrote:
> > Hi Even,
> > Thanks for your valuable feedback.
> > The homepage would be a "superset" of all available Mapfiles in a
> > MapServer deployment, as listed in the CONFIG file. Each individual
> > Mapfile would still have its own OGC API landing page, so the homepage
> > is best described as a directory of all landing pages.
> > As most MapServer deployments will likely be serving out a combination
> > of WxS and new OGC API services for some time to come, it will allow
> > both types to be listed together (I'm unaware of a OGC API spec that
> > would cover this).
> > In regard to the JSON used for links, I was modelling it as closely as
> > possible to OGC API conventions. Looking at the pygeoapi demo home
> > page, it provides a set of links in a common format, so I'll likely
> > switch to this format/approach:
> > https://demo.pygeoapi.io/stable?f=json
> > A few of the "rel" values are defined as below, and can be reused:
> > alternate Provides an alternate representation (e.g., HTML version
> of a
> > resource).
> > service-desc Links to the machine-readable API description (e.g.,
> > OpenAPI JSON).
> > service-doc Links to the human-readable API documentation (e.g.,
> > OpenAPI HTML).
> > conformance Lists the standards and conformance classes supported by
> > the API.
> > I'll update the RFC with the above,
> > Seth
> > On Sat, Jan 18, 2025, at 12:39 PM, Even Rouault wrote:
> >> Seth,
> >> Thanks for putting this together. I'm wondering how much your proposal
> >> relates/intersects with the concept of the landing page of OGC API
> >> services ? You mention some connection with it, but it is not
> >> immediately clear to me the exact nature of the connection. Perhaps it
> >> is just a matter of clarifying. I have put zero thoughts in it, but it
> >> would feel weird to invent a MapServer specific thing, so I'm naively
> >> wondering if we can't we just adopt the landing page formalism (for the
> >> JSON part), and potentially extend it by exposing old WxS services as
> >> well in the links as you suggest? I'm also wondering if there's some
> >> best practice used by other projects on how to expose for things like
> >> "href":
> https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
> >> "title": "GetCapabilities",
> >> "type": "WMS"
> >> so they can be interoperably consumed.
> >> Even
> >> Le 18/01/2025 à 09:11, Seth G via MapServer-dev a écrit :
> >>> Hi devs,
> >>> I've drafted an RFC with an approach of creating a MapServer homepage
> based on the MAPs referenced in a mapserver.conf file. This will allow
> MapServer installations to easily advertise available services, dynamically.
> >>> Text available in pull request at
> https://github.com/MapServer/MapServer-documentation/pull/996
> >>> Comments and thoughts appreciated,
> >>> Thanks,
> >>> Seth
> >>> _______________________________________________
> >>> MapServer-dev mailing list
> >>> MapServer-dev at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >> http://www.spatialys.com
> >> My software is free, but my time generally not.
> >> Butcher of all kinds of standards, open or closed formats. At the end,
> >> this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20250119/684ffa9d/attachment-0001.htm>
More information about the MapServer-dev
