[MapServer-dev] Using OGR geoparquet data in mapserver - spatial filtering works
Michael Smith
michael.smith.erdc at gmail.com
Mon Jul 21 08:52:40 PDT 2025
And spatial filtering is working, it was due to BBOX sorting that it was not being very efficient in the spatial filtering.
Is there a method to use SQLite dialect with MapServer queries with parquet and OGR? Wanted to use SAMPLE but this is only supported via SQLite dialect.
Mike
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
Date: Monday, July 21, 2025 at 10:05 AM
To: Michael Smith <michael.smith.erdc at gmail.com>, MapServer-dev <mapserver-dev at lists.osgeo.org>
Subject: Re: [MapServer-dev] Using OGR geoparquet data in mapserver - no spatial filtering
Mike,
Anyone know a current way to get mapserver to add spatial filtering on OGR geoparquet layers. Have been unable to get the actual sql query being used with CPL_DEBUG inside mapserver with CONFIG "CPL_DEBUG" "ON" but from the performance, it appears no spatial filtering is being done. I suspect code changes to mapogr would be needed to do this but wondering if anyone else has looked into this.
I haven't tried but I would assume this should work
Also, I tried using ADBC connection to parquet, and while it worked (technically) it really used an excessive amount of CPU and memory over using the geoparquet driver.
Yes this is "expected". I noticed that the Arrow API of duckdb tends to ingest everything in memory before paging results.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20250721/41844320/attachment.htm>
More information about the MapServer-dev
