[MapServer-dev] Using OGR geoparquet data in mapserver - spatial filtering works
Seth G
sethg at geographika.co.uk
Tue Jul 22 03:20:31 PDT 2025
Hi Mike,
I don't think so, but coincidentally I was checking yesterday as it would allow some of the functions such as:
DATA "SELECT ObjectId, ST_Z(geometry) Z FROM mydata"
There is the CONNECTIONOPTIONS block, but this doesn't support a "--dialect" equivalent when testing. It would be nice to do something as follows:
CONNECTIONOPTIONS
"dialect" "sqlite"
END
Or alternatively adding in:
PROCESSING 'ogr_dialect=sqlite'
The MapServer OGR code would also need to be updated.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Mon, Jul 21, 2025, at 5:52 PM, Michael Smith via MapServer-dev wrote:
> And spatial filtering is working, it was due to BBOX sorting that it was not being very efficient in the spatial filtering.
> Is there a method to use SQLite dialect with MapServer queries with parquet and OGR? Wanted to use SAMPLE but this is only supported via SQLite dialect.
> Mike
> Michael Smith
> RSGIS Center – ERDC CRREL NH
> US Army Corps
> *From: *Even Rouault <even.rouault at spatialys.com>
> *Date: *Monday, July 21, 2025 at 10:05 AM
> *To: *Michael Smith <michael.smith.erdc at gmail.com>, MapServer-dev <mapserver-dev at lists.osgeo.org>
> *Subject: *Re: [MapServer-dev] Using OGR geoparquet data in mapserver - no spatial filtering
> Mike,
>> Anyone know a current way to get mapserver to add spatial filtering on OGR geoparquet layers. Have been unable to get the actual sql query being used with CPL_DEBUG inside mapserver with CONFIG "CPL_DEBUG" "ON" but from the performance, it appears no spatial filtering is being done. I suspect code changes to mapogr would be needed to do this but wondering if anyone else has looked into this.
> I haven't tried but I would assume this should work
>> Also, I tried using ADBC connection to parquet, and while it worked (technically) it really used an excessive amount of CPU and memory over using the geoparquet driver.
> Yes this is "expected". I noticed that the Arrow API of duckdb tends to ingest everything in memory before paging results.
> Even
> -- http://www.spatialys.comMy software is free, but my time generally not.
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20250722/16906721/attachment.htm>
More information about the MapServer-dev
