[MapServer-dev] CONNECTIONTYPE OGR, specifying dialect?
Scott public at postholer.com
Mon Sep 22 11:29:52 PDT 2025
Greetings,
My understanding is CONNECTIONTYPE OGR uses GDAL directly. Assuming
this, I'm trying to access the sqlite/spatialite dialect in the SQL
query below. Any option for setting dialect?
I've also tried an "<OGRVRTDataSource..." string in CONNECTION with
dialect="sqlite", no luck.
Yes, my libgdal is built with sqlite/spatialite.
The following runs without error, no errors/warnings in the log file.
All other layers render, but this layer does not. If I remove the
DATA/query line it will render. Query runs fine with gdal ogr* command
at the command line (with -dialect sqlite)
Any suggestions?
    CONNECTIONTYPE OGR
    CONNECTION "/path/to/data.fgb"
    DATA "select
	   geom
	   ,st_area(geom) as area
	from table"
    CONNECTIONOPTIONS
       "VERIFY_BUFFERS" "NO"
    END
    PROCESSING "CLOSE_CONNECTION=DEFER"
Thank you!
Scott
www.postholer.com
More information about the MapServer-dev mailing list
