[MapServer-dev] CONNECTIONTYPE OGR, specifying dialect?
    Scott
    public at postholer.com
    Mon Sep 22 11:37:57 PDT 2025
Please disregard last email. That will NEVER work with a .fgb file. I
tested with a .gpkg on the command line.
Apologies,
Scott
On 9/22/25 11:29, Scott via MapServer-dev wrote:
> Greetings,
> My understanding is CONNECTIONTYPE OGR uses GDAL directly. Assuming
> this, I'm trying to access the sqlite/spatialite dialect in the SQL
> query below. Any option for setting dialect?
> I've also tried an "<OGRVRTDataSource..." string in CONNECTION with
> dialect="sqlite", no luck.
> Yes, my libgdal is built with sqlite/spatialite.
> The following runs without error, no errors/warnings in the log file.
> All other layers render, but this layer does not. If I remove the DATA/
> query line it will render. Query runs fine with gdal ogr* command at the
> command line (with -dialect sqlite)
> Any suggestions?
>     CONNECTIONTYPE OGR
>     CONNECTION "/path/to/data.fgb"
>     DATA "select
>         geom
>         ,st_area(geom) as area
>      from table"
>     CONNECTIONOPTIONS
>        "VERIFY_BUFFERS" "NO"
>     END
>     PROCESSING "CLOSE_CONNECTION=DEFER"
> Thank you!
> Scott
> www.postholer.com
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev
