[MapServer-dev] Proposal of a new MS_ONLINERESOURCE variable
Seth G
sethg at geographika.co.uk
Fri Feb 6 09:53:16 PST 2026
Hi all,
One of the pain-points of MapServer deployments are setting the "ows_getcapabilities" for each Mapfile for each
environment.
I wrote an RFC at https://github.com/MapServer/MapServer-documentation/pull/1059 that allows you to set this once for all Mapfiles in a deployment in the CONFIG file.
After going through the code, it is actually a minimal change to msBuildOnlineResource that could have been a simple pull-request. However I had enough notes to add to the RFC, and thought it would be good to get feedback on the MS_ONLINERESOURCE name and approach.
I'll start with my +1.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
More information about the MapServer-dev
