[MapServer-dev] Proposal of a new MS_ONLINERESOURCE variable
Michael Smith
michael.smith.erdc at gmail.com
Fri Feb 6 09:58:09 PST 2026
I like it.
+1 Mike
On 2/6/26, 12:53 PM, "MapServer-dev on behalf of Seth G via MapServer-dev" <mapserver-dev-bounces at lists.osgeo.org <mailto:mapserver-dev-bounces at lists.osgeo.org> on behalf of mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>> wrote:
Hi all,
One of the pain-points of MapServer deployments are setting the "ows_getcapabilities" for each Mapfile for each
environment.
I wrote an RFC at https://github.com/MapServer/MapServer-documentation/pull/1059 <https://github.com/MapServer/MapServer-documentation/pull/1059> that allows you to set this once for all Mapfiles in a deployment in the CONFIG file.
After going through the code, it is actually a minimal change to msBuildOnlineResource that could have been a simple pull-request. However I had enough notes to add to the RFC, and thought it would be good to get feedback on the MS_ONLINERESOURCE name and approach.
I'll start with my +1.
Seth
web:https://geographika.net <https://geographika.net> & https://mapserverstudio.net <https://mapserverstudio.net>
mastodon: @geographika at mastodon.soci <mailto:geographika at mastodon.soci>al
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-dev <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
More information about the MapServer-dev
