[MapServer-dev] Proposal of a new MS_ONLINERESOURCE variable
Even Rouault
even.rouault at spatialys.com
Fri Feb 6 10:06:37 PST 2026
+1 Even
Le 06/02/2026 à 18:53, Seth G via MapServer-dev a écrit :
> Hi all,
> One of the pain-points of MapServer deployments are setting the "ows_getcapabilities" for each Mapfile for each
> environment.
> I wrote an RFC at https://github.com/MapServer/MapServer-documentation/pull/1059 that allows you to set this once for all Mapfiles in a deployment in the CONFIG file.
> After going through the code, it is actually a minimal change to msBuildOnlineResource that could have been a simple pull-request. However I had enough notes to add to the RFC, and thought it would be good to get feedback on the MS_ONLINERESOURCE name and approach.
> I'll start with my +1.
> Seth
> web:https://geographika.net & https://mapserverstudio.net
> mastodon: @geographika at mastodon.social
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
More information about the MapServer-dev
