[MapServer-dev] Proposal of a new MS_ONLINERESOURCE variable
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Sat Feb 7 01:07:59 PST 2026
+1
-Jukka Rahkonen-
________________________________________
Lähettäjä: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> käyttäjän Seth G via MapServer-dev <mapserver-dev at lists.osgeo.org> puolesta
Lähetetty: Perjantai 6. helmikuuta 2026 19.53
Vastaanottaja: MapServer Devs <mapserver-dev at lists.osgeo.org>
Aihe: [MapServer-dev] Proposal of a new MS_ONLINERESOURCE variable
Hi all,
One of the pain-points of MapServer deployments are setting the "ows_getcapabilities" for each Mapfile for each
environment.
I wrote an RFC at https://github.com/MapServer/MapServer-documentation/pull/1059 that allows you to set this once for all Mapfiles in a deployment in the CONFIG file.
After going through the code, it is actually a minimal change to msBuildOnlineResource that could have been a simple pull-request. However I had enough notes to add to the RFC, and thought it would be good to get feedback on the MS_ONLINERESOURCE name and approach.
I'll start with my +1.
Seth
web:https://geographika.net/ & https://mapserverstudio.net/
mastodon: @geographika at mastodon.social
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev
