[MapServer-dev] Mailing List Issues
Seth G sethg at geographika.co.uk
Fri Jan 23 06:14:31 PST 2026
Hi Jeff,
Thanks for the background details, and it's reassuring the MapServer lists aren't badly affected.
Hopefully, mailing lists will continue to be supported by SAC. I know there is a push to use Discourse, but I can't see a whole online community moving across to a new platform without losing lots of members.
Seth
web:https://geographika.net
mastodon: @geographika at mastodon.social
On Fri, Jan 23, 2026, at 1:32 PM, Jeff McKenna via MapServer-dev wrote:
> Hi Seth,
> My apologies for the delay in my response, I was still sleeping when you
> sent this message.
> Frank and I manage the -users and -dev lists.
> I was also affected by this problem: I believe that my email address is
> blocked from all OSGeo lists currently.
> Background: this happened when SAC switched mail server hosts, and OSGeo
> was blacklisted when the IP addresses changed.   I first saw mention of
> this in December through
> https://lists.osgeo.org/pipermail/sac/2025-December/016916.html
> I have now checked MapServer-users and MapServer-dev, and there was only
> one address blocked ("no reason: B").  I removed that now.
> I am also an admin of gdal-dev, and that list is a whole different
> story, as there are hundreds of addresses with that problem.  Of course,
> it is hard to know if that is a valid block due to bounces, or was it
> due to this mail server switch.   In any case, I went through the
> gdal-dev subscriber list this morning and removed those blocked
> addresses.  (I will now send out test messages, and hopefully catch &
> remove the bounces email addresses sent back to me)
> Sorry for the hassle, but, put plainly: my address is also now blocked
> from all OSGeo lists due to that episode, I hope that SAC tackles this,
> through a batch update for all OSGeo mailing lists.
> Thanks,
> -jeff
> On 2026-01-23 5:10 a.m., Seth G via MapServer-dev wrote:
>> Hi all,
>> I stopped receiving email from the gdal-dev mailing list on December 5th last year. I also missed several mapserver-users posts for around a week at the same time (although this restarted).
>> It appears some subscribers were blocked without warning / notice and had to be manually unblocked - see https://trac.osgeo.org/osgeo/ticket/3506#ticket
>> I'm wondering if the same has happened to anyone on the mapserver-users and mapserver-dev (not that they'll get this email if they have..)? I'm not sure who has admin access to check. I'll also request access from OSGeo SAC so I can check myself.
>> Seth
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev mailing list
