[MapServer-dev] Mailing List Issues
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Jan 23 05:09:33 PST 2026
Correction: the Mailman exact setting was ("no mail: B")
-jeff
On 2026-01-23 8:32 a.m., Jeff McKenna wrote:
> Hi Seth,
> My apologies for the delay in my response, I was still sleeping when you
> sent this message.
> Frank and I manage the -users and -dev lists.
> I was also affected by this problem: I believe that my email address is
> blocked from all OSGeo lists currently.
> Background: this happened when SAC switched mail server hosts, and OSGeo
> was blacklisted when the IP addresses changed.   I first saw mention of
> this in December through https://lists.osgeo.org/pipermail/sac/2025-
> December/016916.html
> I have now checked MapServer-users and MapServer-dev, and there was only
> one address blocked ("no reason: B").  I removed that now.
> I am also an admin of gdal-dev, and that list is a whole different
> story, as there are hundreds of addresses with that problem.  Of course,
> it is hard to know if that is a valid block due to bounces, or was it
> due to this mail server switch.   In any case, I went through the gdal-
> dev subscriber list this morning and removed those blocked addresses.
> (I will now send out test messages, and hopefully catch & remove the
> bounces email addresses sent back to me)
> Sorry for the hassle, but, put plainly: my address is also now blocked
> from all OSGeo lists due to that episode, I hope that SAC tackles this,
> through a batch update for all OSGeo mailing lists.
> Thanks,
> -jeff
> On 2026-01-23 5:10 a.m., Seth G via MapServer-dev wrote:
>> Hi all,
>> I stopped receiving email from the gdal-dev mailing list on December
>> 5th last year. I also missed several mapserver-users posts for around
>> a week at the same time (although this restarted).
>> It appears some subscribers were blocked without warning / notice and
>> had to be manually unblocked - see https://trac.osgeo.org/osgeo/
>> ticket/3506#ticket
>> I'm wondering if the same has happened to anyone on the mapserver-
>> users and mapserver-dev (not that they'll get this email if they
>> have..)? I'm not sure who has admin access to check. I'll also request
>> access from OSGeo SAC so I can check myself.
>> Seth
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-dev mailing list
