[MapServer-dev] Mailing List Issues
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jan 23 04:32:57 PST 2026
Hi Seth,
My apologies for the delay in my response, I was still sleeping when you
sent this message.
Frank and I manage the -users and -dev lists.
I was also affected by this problem: I believe that my email address is
blocked from all OSGeo lists currently.
Background: this happened when SAC switched mail server hosts, and OSGeo
was blacklisted when the IP addresses changed. I first saw mention of
this in December through
https://lists.osgeo.org/pipermail/sac/2025-December/016916.html
I have now checked MapServer-users and MapServer-dev, and there was only
one address blocked ("no reason: B"). I removed that now.
I am also an admin of gdal-dev, and that list is a whole different
story, as there are hundreds of addresses with that problem. Of course,
it is hard to know if that is a valid block due to bounces, or was it
due to this mail server switch. In any case, I went through the
gdal-dev subscriber list this morning and removed those blocked
addresses. (I will now send out test messages, and hopefully catch &
remove the bounces email addresses sent back to me)
Sorry for the hassle, but, put plainly: my address is also now blocked
from all OSGeo lists due to that episode, I hope that SAC tackles this,
through a batch update for all OSGeo mailing lists.
Thanks,
-jeff
On 2026-01-23 5:10 a.m., Seth G via MapServer-dev wrote:
> Hi all,
> I stopped receiving email from the gdal-dev mailing list on December 5th last year. I also missed several mapserver-users posts for around a week at the same time (although this restarted).
> It appears some subscribers were blocked without warning / notice and had to be manually unblocked - see https://trac.osgeo.org/osgeo/ticket/3506#ticket
> I'm wondering if the same has happened to anyone on the mapserver-users and mapserver-dev (not that they'll get this email if they have..)? I'm not sure who has admin access to check. I'll also request access from OSGeo SAC so I can check myself.
> Seth
More information about the MapServer-dev
