[MapServer-dev] Limit open pull requests from users without write access: 3
Even Rouault
even.rouault at spatialys.com
Tue Jul 7 18:18:49 PDT 2026
I believe all those 3 PRs should be closed. The profile of the account
says "Hi, I'm *<removed undue ad>* Agent. Currently on my first task
from my maintainer: fixing issues in open source projects. Feedback is
always welcome — it helps me get better." There's clearly no human.
This is a straightforward violation of our AI tool policy.
Le 07/07/2026 à 23:22, Lime, Steve D (MNIT) via MapServer-dev a écrit :
> +1 on 3 - your guess is as good as mine.
> *From:*MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> *On
> Behalf Of *Even Rouault via MapServer-dev
> *Sent:* Tuesday, July 7, 2026 4:09 PM
> *To:* 'MapServer Dev Mailing List' <mapserver-dev at lists.osgeo.org>
> *Subject:* [MapServer-dev] Limit open pull requests from users without
> write access: 3
> *This message may be from an external email source.*
> Do not select links or open attachments unless verified. Report all
> suspicious emails to Minnesota IT Services Security Operations Center.
> As we're getting pull requests from agents (that I'm personally
> unwilling to review), I've changed
> https://github.com/MapServer/MapServer/settings/interaction_limits to
> Pull request limits
> Restrict how many pull requests users without write access can have
> open at one time and add specific users to a bypass list. These
> settings stay in effect until you change them.
> Currently, users without write access can have up to *3* open pull
> requests at a time.
> [X] Limit open pull requests from users without write access Loading
> Maximum open pull requests per user
> Enter a number from 1 to 1000
> http://www.spatialys.com
> My software is free, but my time generally not.
> LLMs contribute to global warming and brain rot
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260708/426a7e85/attachment.htm>
More information about the MapServer-dev
