[MapServer-dev] Limit open pull requests from users without write access: 3
Seth G sethg at geographika.co.uk
Wed Jul 8 01:58:36 PDT 2026
+1 to the limit.
I would say we should link to the AI policy and give a warning to https://github.com/loom-agent but as the profile says it is an agent we can just close these. Tamas already tried the fix in https://github.com/MapServer/MapServer/pull/7565 without it resolving the issue (based on reading the comments).
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Wed, Jul 8, 2026, at 4:18 AM, Even Rouault via MapServer-dev wrote:
> I believe all those 3 PRs should be closed. The profile of the account says "Hi, I'm *<removed undue ad>* Agent. Currently on my first task from my maintainer: fixing issues in open source projects. Feedback is always welcome — it helps me get better."   There's clearly no human. This is a straightforward violation of our AI tool policy.
> Le 07/07/2026 à 23:22, Lime, Steve D (MNIT) via MapServer-dev a écrit :
>> +1 on 3 - your guess is as good as mine.
>> *From:* MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> *On Behalf Of *Even Rouault via MapServer-dev
>> *Sent:* Tuesday, July 7, 2026 4:09 PM
>> *To:* 'MapServer Dev Mailing List' <mapserver-dev at lists.osgeo.org>
>> *Subject:* [MapServer-dev] Limit open pull requests from users without write access: 3
>> *This message may be from an external email source.*
>> Do not select links or open attachments unless verified. Report all suspicious emails to Minnesota IT Services Security Operations Center.
>> As we're getting pull requests from agents (that I'm personally unwilling to review), I've changed https://github.com/MapServer/MapServer/settings/interaction_limits to
>> Pull request limits
>> Restrict how many pull requests users without write access can have open at one time and add specific users to a bypass list. These settings stay in effect until you change them.
>> Currently, users without write access can have up to *3* open pull requests at a time.
>> [X] Limit open pull requests from users without write access Loading
>> Maximum open pull requests per user
>> Enter a number from 1 to 1000
>> -- http://www.spatialys.comMy software is free, but my time generally not.LLMs contribute to global warming and brain rot
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260708/4d75e4fb/attachment-0001.htm>
More information about the MapServer-dev mailing list
