[MapServer-dev] Limit open pull requests from users without write access: 3
jbo-ads at mailo.com jbo-ads at mailo.com
Wed Jul 8 02:27:44 PDT 2026
+1 on a limit of 3
On 7/8/26 10:58, Seth G via MapServer-dev wrote:
> +1 to the limit.
> I would say we should link to the AI policy and give a warning to
> https://github.com/loom-agent but as the profile says it is an agent
> we can just close these. Tamas already tried the fix in
> https://github.com/MapServer/MapServer/pull/7565 without it resolving
> the issue (based on reading the comments).
> web:https://geographika.net & https://mapserverstudio.net
> mastodon: @geographika at mastodon.social
> On Wed, Jul 8, 2026, at 4:18 AM, Even Rouault via MapServer-dev wrote:
>> I believe all those 3 PRs should be closed. The profile of the
>> account says "Hi, I'm *<removed undue ad>* Agent. Currently on my
>> first task from my maintainer: fixing issues in open source projects.
>> Feedback is always welcome — it helps me get better."   There's
>> clearly no human. This is a straightforward violation of our AI tool
>> policy.
>> Le 07/07/2026 à 23:22, Lime, Steve D (MNIT) via MapServer-dev a écrit :
>>> +1 on 3 - your guess is as good as mine.
>>> *From:*MapServer-dev <mapserver-dev-bounces at lists.osgeo.org>
>>> <mailto:mapserver-dev-bounces at lists.osgeo.org> *On Behalf Of *Even
>>> *Sent:* Tuesday, July 7, 2026 4:09 PM
>>> *To:* 'MapServer Dev Mailing List' <mapserver-dev at lists.osgeo.org>
>>> <mailto:mapserver-dev at lists.osgeo.org>
>>> *Subject:* [MapServer-dev] Limit open pull requests from users
>>> *This message may be from an external email source.*
>>> Do not select links or open attachments unless verified. Report all
>>> suspicious emails to Minnesota IT Services Security Operations Center.
>>> As we're getting pull requests from agents (that I'm personally
>>> unwilling to review), I've changed
>>> https://github.com/MapServer/MapServer/settings/interaction_limits
>>> <https://github.com/MapServer/MapServer/settings/interaction_limits> to
>>>     Pull request limits
>>> Restrict how many pull requests users without write access can have
>>> open at one time and add specific users to a bypass list. These
>>> settings stay in effect until you change them.
>>> Currently, users without write access can have up to *3* open pull
>>> requests at a time.
>>> [X] Limit open pull requests from users without write access Loading
>>> Maximum open pull requests per user
>>> Enter a number from 1 to 1000
>>> http://www.spatialys.com <http://www.spatialys.com/>
>>> My software is free, but my time generally not.
>>> LLMs contribute to global warming and brain rot
>>> MapServer-dev mailing list
>>> MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>> http://www.spatialys.com <http://www.spatialys.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260708/67391fdd/attachment.htm>
More information about the MapServer-dev mailing list
