[MapServer-dev] Motion: adopt RFC-142: Geodesic Scalebar Measurement
Tamas Szekeres szekerest at gmail.com
Tue Sep 15 02:15:33 PDT 2026
Dear PSC,
I would like to motion to adopt RFC-142: Geodesic Scalebar Measurement. Based
on the discussion of this RFC
<https://lists.osgeo.org/pipermail/mapserver-dev/2026-May/017361.html> I've
simplified the solution by removing the MEASURE parameter (therefore the
RFC has been renamed) and that the result represents horizontal local scale
at the map center (not bound to the actual scalebar location). According to
Even's suggestion, if the project has a CRS we use the geodesic scale,
otherwise fallback to cartesian method.
The modified RFC can be found here:
https://mapserver.org/development/rfc/ms-rfc-142.html
The corresponding PR with the suggested changes:
https://github.com/MapServer/MapServer/pull/7507/changes
Starting with my +1,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260915/e4da48a8/attachment.htm>
More information about the MapServer-dev mailing list
