[MapServer-dev] Motion: adopt RFC-142: Geodesic Scalebar Measurement
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Sep 15 06:40:36 PDT 2026
Hi Tamas,
Thanks for your efforts on this. I am a +1. However, my only concern is
which release this should be included in - my gut feeling is that this
should be included in the MapServer 9.0.0 release.  It seems like quite
a drastic change (but a big improvement) for a minor release.
This might also push us to release 9.0.0 sooner than later.
Thanks,
-jeff
On 2026-09-15 6:15 a.m., Tamas Szekeres via MapServer-dev wrote:
> Dear PSC,
> I would like to motion to adoptRFC-142: Geodesic Scalebar
> Measurement.Based on the discussion of this RFC <https://
> lists.osgeo.org/pipermail/mapserver-dev/2026-May/017361.html> I've
> simplified the solution by removing the MEASURE parameter (therefore the
> RFC has been renamed) and that the result represents horizontal local
> scale at the map center (not bound to the actual scalebar location).
> According to Even's suggestion, if the project has a CRS we use the
> geodesic scale, otherwise fallback to cartesian method.
> The modified RFC can be found here: https://mapserver.org/development/
> rfc/ms-rfc-142.html <https://mapserver.org/development/rfc/ms-rfc-142.html>
> The corresponding PR with the suggested changes: https://github.com/
> MapServer/MapServer/pull/7507/changes <https://github.com/MapServer/
> MapServer/pull/7507/changes>
> Starting with my +1,
> Tamas
More information about the MapServer-dev mailing list
