[MapServer-dev] Motion: adopt RFC-142: Geodesic Scalebar Measurement
Tom Kralidis
tomkralidis at gmail.com
Tue Sep 15 07:01:08 PDT 2026
+1 (targeting for 9.0.0).
..Tom
On Tue, Sep 15, 2026 at 9:43 AM Tamas Szekeres via MapServer-dev
<mapserver-dev at lists.osgeo.org> wrote:
> Hi Jeff,
> Thank you, I'm fine with that plan.
> Best regards,
> Tamas
> Jeff McKenna via MapServer-dev <mapserver-dev at lists.osgeo.org> ezt írta (időpont: 2026. szept. 15., K, 15:40):
>> Hi Tamas,
>> Thanks for your efforts on this. I am a +1. However, my only concern is
>> which release this should be included in - my gut feeling is that this
>> should be included in the MapServer 9.0.0 release. It seems like quite
>> a drastic change (but a big improvement) for a minor release.
>> This might also push us to release 9.0.0 sooner than later.
>> Thanks,
>> -jeff
>> On 2026-09-15 6:15 a.m., Tamas Szekeres via MapServer-dev wrote:
>> > Dear PSC,
>> > I would like to motion to adoptRFC-142: Geodesic Scalebar
>> > Measurement.Based on the discussion of this RFC <https://
>> > lists.osgeo.org/pipermail/mapserver-dev/2026-May/017361.html> I've
>> > simplified the solution by removing the MEASURE parameter (therefore the
>> > RFC has been renamed) and that the result represents horizontal local
>> > scale at the map center (not bound to the actual scalebar location).
>> > According to Even's suggestion, if the project has a CRS we use the
>> > geodesic scale, otherwise fallback to cartesian method.
>> > The modified RFC can be found here: https://mapserver.org/development/
>> > rfc/ms-rfc-142.html <https://mapserver.org/development/rfc/ms-rfc-142.html>
>> > The corresponding PR with the suggested changes: https://github.com/
>> > MapServer/MapServer/pull/7507/changes <https://github.com/MapServer/
>> > MapServer/pull/7507/changes>
>> > Starting with my +1,
>> > Tamas
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev
