[MapServer-dev] Motion: adopt RFC-142: Geodesic Scalebar Measurement
Michael Smith
michael.smith.erdc at gmail.com
Wed Sep 16 03:44:36 PDT 2026
+1
Mike
From: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> on behalf of Seth G via MapServer-dev <mapserver-dev at lists.osgeo.org>
Reply-To: Seth G <sethg at geographika.co.uk>
Date: Wednesday, September 16, 2026 at 1:57 AM
To: Tamas Szekeres <szekerest at gmail.com>, MapServer Devs <mapserver-dev at lists.osgeo.org>
Subject: Re: [MapServer-dev] Motion: adopt RFC-142: Geodesic Scalebar Measurement
+1 thanks Tamas.
(as an aside, QGIS also seems to default to centre of the map for scale: https://docs.qgis.org/3.44/en/docs/user_manual/introduction/qgis_configuration.html#scale-calculation-method)
Seth
On Tue, Sep 15, 2026, at 11:15 AM, Tamas Szekeres via MapServer-dev wrote:
Dear PSC,
I would like to motion to adopt RFC-142: Geodesic Scalebar Measurement. Based on the discussion of this RFC I've simplified the solution by removing the MEASURE parameter (therefore the RFC has been renamed) and that the result represents horizontal local scale at the map center (not bound to the actual scalebar location). According to Even's suggestion, if the project has a CRS we use the geodesic scale, otherwise fallback to cartesian method.
The modified RFC can be found here: https://mapserver.org/development/rfc/ms-rfc-142.html
The corresponding PR with the suggested changes: https://github.com/MapServer/MapServer/pull/7507/changes
Starting with my +1,
Tamas
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
_______________________________________________ MapServer-dev mailing list MapServer-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260916/3fd140fe/attachment-0001.htm>
More information about the MapServer-dev
