[MapServer-dev] Motion: adopt RFC-142: Geodesic Scalebar Measurement
Tamas Szekeres szekerest at gmail.com
Sat Sep 19 12:11:39 PDT 2026
Dear PSC,
I declare this motion passed with +1 from the PSC members: JeffM, TomK,
SethG, MikeS, SteveL and me.
MS-RFC-142 <https://mapserver.org/development/rfc/ms-rfc-142.html> has been
updated with the voting result and the suggested target version.
I'll go ahead with incorporating the changes and update the documentation
accordingly.
Best regards,
Tamas
Tamas Szekeres <szekerest at gmail.com> ezt írta (időpont: 2026. szept. 15.,
K, 11:15):
> Dear PSC,
> I would like to motion to adopt RFC-142: Geodesic Scalebar Measurement. Based
> on the discussion of this RFC
> <https://lists.osgeo.org/pipermail/mapserver-dev/2026-May/017361.html>
> I've simplified the solution by removing the MEASURE parameter (therefore
> the RFC has been renamed) and that the result represents horizontal local
> scale at the map center (not bound to the actual scalebar location).
> According to Even's suggestion, if the project has a CRS we use the
> geodesic scale, otherwise fallback to cartesian method.
> The modified RFC can be found here:
> The corresponding PR with the suggested changes:
> https://github.com/MapServer/MapServer/pull/7507/changes
> Starting with my +1,
> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260919/af84e960/attachment.htm>
More information about the MapServer-dev mailing list
