[Mapserver-inspire] View Service Validator
Guillaume Sueur no-reply at neogeo-online.net
Thu May 26 04:58:27 EDT 2011
Thanks for your feedback Martin. Is there a public URL from which we can
test your Capabilities to fix that problem ?
Best regards
Guillaume
Le 25/05/2011 19:50, Martin Kofahl a écrit :
> Hi Guillaume -
> this is a very good project!
> I have some problems with the encoding, error is
> Exception Type: UnicodeDecodeError
> Exception Value: 'ascii' codec can't decode byte 0xc3 in position 9: ordinal not in range(128)
> The server response, containing german umlauts in iso-8859-1 is:
> HTTP/1.1 200 OK
> Date: Wed, 25 May 2011 17:43:21 GMT
> Server: Apache
> Cache-Control: max-age=3600
> Expires: Wed, 25 May 2011 18:43:21 GMT
> Connection: close
> Content-Type: text/xml
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> Kind regards,
> Martin
> -------- Original-Nachricht --------
>> Datum: Wed, 25 May 2011 10:00:36 +0200
>> Von: Guillaume Sueur<no-reply at neogeo-online.net>
>> An: mapserver-inspire at lists.osgeo.org
>> Betreff: [Mapserver-inspire] View Service Validator
>> Folks,
>> We are currently setting up an online application for testing view
>> services compliance with INSPIRE.
>> You can find it here : http://188.165.244.186/inspire_tester/ (only in
>> french for the moment, but it's quite simple to use, just put an URL
>> into the empty field...)
>> Comments are welcome.
>> Our goal is to provide a full ISO-19128 INSPIRE View service checker. I
>> guess many tests still need to be implemented. Don't hesitate to test
>> various services.
>> Best regards
>> Guillaume Sueur
>> Mapserver-inspire mailing list
>> Mapserver-inspire at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-inspire
More information about the Mapserver-inspire mailing list
