[Mapserver-inspire] View Service Validator
Martin Kofahl M.Kofahl at gmx.net
Wed May 25 13:50:07 EDT 2011
Hi Guillaume -
this is a very good project!
I have some problems with the encoding, error is
Exception Type: UnicodeDecodeError
Exception Value: 'ascii' codec can't decode byte 0xc3 in position 9: ordinal not in range(128)
The server response, containing german umlauts in iso-8859-1 is:
HTTP/1.1 200 OK
Date: Wed, 25 May 2011 17:43:21 GMT
Server: Apache
Cache-Control: max-age=3600
Expires: Wed, 25 May 2011 18:43:21 GMT
Connection: close
Content-Type: text/xml
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
Kind regards,
Martin
-------- Original-Nachricht --------
> Datum: Wed, 25 May 2011 10:00:36 +0200
> Von: Guillaume Sueur <no-reply at neogeo-online.net>
> An: mapserver-inspire at lists.osgeo.org
> Betreff: [Mapserver-inspire] View Service Validator
> Folks,
> We are currently setting up an online application for testing view
> services compliance with INSPIRE.
> You can find it here : http://188.165.244.186/inspire_tester/ (only in
> french for the moment, but it's quite simple to use, just put an URL
> into the empty field...)
> Comments are welcome.
> Our goal is to provide a full ISO-19128 INSPIRE View service checker. I
> guess many tests still need to be implemented. Don't hesitate to test
> various services.
> Best regards
> Guillaume Sueur
> Mapserver-inspire mailing list
> Mapserver-inspire at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-inspire
More information about the Mapserver-inspire mailing list
