Projections and debugging web processes
Cameron Shorter
cshorter at optusnet.com.au
Mon Aug 23 18:00:24 EDT 1999
I belive I have worked out how to debug mapserv.cgi. I set up
environment variables and then run from the command line, and hence can
attach the gdb debugger. Ie, in my .bashrc I set the following:
# Env variables for debugging mapserv
QUERY_STRING="map=%2Fhome%2Fbikeast%2Fcamerons%2Fbikeast_amg56.map&layer=onroad"
REQUEST_METHOD="GET"
export QUERY_STRING REQUEST_METHOD
My files are in lat/long coordinates and I want to convert them to
AMG56.
The mapfile works if I comment out all the projection data.
I have been using gdb to try and debug mapserv.cgi and compare it to
shp2gif. The problem seems to be in msAdjustExtent, but I haven't
worked it out yet. I will be doing more work on it over the next few
days (if you cannot give me a few hints in the meantime).
The mapfile I'm using is below:
# Start of map file
NAME BIKEAST
STATUS ON
SIZE 300 300
SHADESET /www/mapserv/ms_symbols/symbols/shade.sym
MARKERSET /www/mapserv/ms_symbols/symbols/marker.sym
LINESET /www/mapserv/ms_symbols/symbols/line.sym
# Lat Long coordinates
#EXTENT 151.203 -33.9247 151.286 -33.8405
# amg56 coordinates
EXTENT 333893.70 6244726.01 341410.96 6254194.63
#EXTENT 333893.70+6244726.01+341410.96+6254194.63
# Extent provided by Rob
#EXTENT 323912.333333 6229086.333333 350370.666667 6255544.666667
#EXTENT 323912.333333+6229086.333333+350370.666667+6255544.666667
UNITS KILOMETERS
SHAPEPATH "/home/bikeast/camerons/data"
IMAGECOLOR 255 255 255
PROJECTION
"proj=utm"
"ellps=aust_SA"
"zone=56"
"south"
END
INTERLACE off
LABELOVERLAP FALSE
# Start of web interface definition
WEB
HEADER bikeast_header.html
TEMPLATE bikeast.html
MINSCALE 1
MAXSCALE 1550000
END
# Start of reference map
REFERENCE
IMAGE graphics/reference_base.gif
#IMAGE
http://nccnsw.org.au/cgi-bin/csgi/broker/delivery_agent.pl?filename=/www/hosted/nccnsw/cgi-bin/csgi/broker/cache/930655471_13239_1.gif
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS MILES
INTERVALS 5
STATUS ON
END
# Start of layer definitions
LAYER
NAME "topo25k"
TYPE RASTER
STATUS ON
DATA topo25k.tif
#OFFSITE 0
PROJECTION
Geographic
"ellps=aust_SA"
END
END # Layer
LAYER
NAME onroad
TYPE LINE
STATUS ON
DATA onroad
TOLERANCE 5
PROJECTION
Geographic
"ellps=aust_SA"
END
CLASSITEM "STATUS"
CLASS
NAME "Onroad - adopted"
EXPRESSION "a"
COLOR 0 0 255
SYMBOL 1
END
CLASS
NAME "Onroad - BIKEast"
EXPRESSION "b"
COLOR 0 255 0
SYMBOL 2
END
CLASS
NAME "Individual"
EXPRESSION "i"
COLOR 127 127 0
SYMBOL 3
END
QUERY
TEMPLATE onroad.html
END
END # Layer
LAYER
NAME offroad
TYPE LINE
STATUS ON
DATA offroad
TOLERANCE 5
PROJECTION
Geographic
"ellps=aust_SA"
END
CLASS
NAME "offroad"
COLOR 255 0 0
SYMBOL 1
END
QUERY
TEMPLATE offroad.html
END
END # Layer
LAYER
NAME "blackspot"
TYPE POINT
STATUS ON
DATA blackspot
TOLERANCE 5
PROJECTION
Geographic
"ellps=aust_SA"
END
CLASS
NAME "blackspot"
COLOR 255 0 0
SIZE 0
END
QUERY
END
END # Layer
END # Map File
Stephen Lime wrote:
> How are you initializing the web process? Are you sure intial extents are correct and are in the correct coordinate system? Everything should be in the maps projection. Individual layers are converted to that (if necessary) but no other coordinates.
> Does the demo work with that install or is this all new to this particular compiled version?
> Debugging web stuff ain't fun. If you're using apache (don't know about others) then you can just print to stderr and messages will show up in the logs.
> Steve
> <<< Cameron Shorter <cshorter at optusnet.com.au> 8/17 7:31a >>>
> I have been trying to get projections working. So far I have been able
> to get shp2gif to draw map using my projections map file, but for some
> reason it doesn't work when I call mapserver from the web for that
> mapfile. Mapserv does work for other non-projection map files.
> Does anyone know:
> 1. Why shp2gif would work, but mapserv only produces a blank page.
> 2. How to attach a gdb to a web process.
> 3. Other ideas on debugging.
> Cameron.
