I've been trying to narrow down the source of the problem a little more. If I change from TT fonts to bitmap, I can display more labels on a map before it crashes, but it does still crash. Since the problem seems not to be limited to TrueType fonts, I'll see if I can use the shp2img interface and bitmap fonts to try and isolate the problem. PGA
