Mapscript question
Paul G. Allen
pgallen at randomlogic.com
Mon Dec 20 14:20:28 EST 1999
I didn't see my other post show up on the list, so here it is again.
I'm a little confused about the use of 'new'. What does the following
line do:
$map = new mapObj("<filname>.map");
Does it create a map file with the name <filename>.map or does it create
an object in Mapscript using an existing file whose name is
<filename>.map, so that it can be referenced/used in Mapscript?
PGA
