Mapscript problems
    Brent Fraser
    bfraser at geoanalytic.com
    Thu Dec 23 07:23:17 PST 1999
Paul,
  There was a change in the msLoadMap function from 3.3 alpha to 3.3 beta
(I'm assuming the change is reflected in MapScript too).  Try using two
parameters for mapObj, the first one is a map file as you've done, and the
second one is the path to your mapserv.ini file (excluding the filename).
For example:
$map = new
mapObj("/home/httpd/html/SD/sandiego.map","/home/httpd/cgi-bin/");
but I'm not a MapScript guy...
Brent
----- Original Message -----
To: "MapServer Users List" <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, December 23, 1999 8:36 AM
Subject: Mapscript problems
> I'm getting an error when trying to instantiate a new mapObj. The code
looks
> like this:
> $map = new mapObj("/home/httpd/html/SD/sandiego.map");
> and the error is:
> Usage: new_mapObj(filename,config); at
<mapscript_module_path>/mapscript.pm line
> 1479
> I am still using the last alpha version of MapServer 3.3. (I have not
updated
> yet because I'd have to mess with the code to get it to work on my Alpha,
and
> I've been saving that for a good stable release.)
> The map file does exist in the path indicated and permissions are correct.
> PGA
More information about the MapServer-users
