ActiveX version of Mapserver
imap at chesapeake.net
Mon Jul 12 15:16:28 EDT 1999
About this ActiveX version... Are we talking about
setting up COM (Component Object Model) for mapserv?
I think that MapScript may be for the benefit of
perl users, but the object access part of Steve's
MapScript design may be extensible in the Microsoft
world. Steve, can you give us a heads-up about the
construction of Mapscript (components/structures/
objects/access/etc) to get some ideas? I'd like to
see the ActiveX component evolve with the same
idea as MapScript. It should be very similar one would
hope.
Thanks,
-Chris (imap at chesapeake.net)
Brent Fraser wrote:
> ----- Original Message -----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: Banister Trevor <TBanister at SpaceImaging.com>
> Sent: Monday, July 12, 1999 10:58 AM
> Subject: Re: ActiveX version of Mapserver
> > I've done some work along the ASP line. I've only implemented
> > a few functions, mostly for reading and writing the members
> > of the map and layer structures. I've put further ASP work on
> > hold until I see what Steve comes up with MapScript (and I'm
> > busy working thru a bug in setting map extents with ASP)
> > If you want some more details, let me know...
> > Brent Fraser
> > From: Banister Trevor <TBanister at SpaceImaging.com>
> > To: <mapserver-users at lists.gis.umn.edu>
> > Sent: Monday, July 12, 1999 10:35 AM
> > Subject: ActiveX version of Mapserver
> > > I've heard rumors about someone compiling Mapserver as an ActiveX ASP
> > > component. I've thought of doing this myself, but if someone has already
> > > done a port I won't re-invent the wheel. Does anyone know of such an
> > effort,
> > > and if the code or binary is available?
> > > Thanks.
> > > Trevor Banister
