3.2.21 Available.
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Oct 1 13:40:41 PDT 1999
Version 3.2.21 is available at the MapServer website. Not a major
release at all. Has 3 fixes:
- Fixes bug with error traps. If parameters are wrong in map file then
the standard ugly old error format is used. Only errors that occur
after initial map file parsing are catchable.
- Fixed bug that caused one-to-many join processor to kick in cases
where an attribute table contained an item name that's a substring of
the join name. Thanks Ken.
- Added DD (decimal degrees) as a valid unit type. You can now use
scale related parameters MINSCALE, MAXSCALE, SYMBOLSCALE
and scalebars with lat/lon data. Remember though, the computed
scale is only accurate at the equator and should be used internally
(i.e. within a map file) only. DD is NOT a valid scalebar unit.
Steve
More information about the MapServer-users
