No subject
Searle Ross
Ross.Searle at dnr.qld.gov.au
Thu Oct 14 03:16:41 EDT 1999
Hi
Anyone got any ideas about what might be causing Version 3.22 to return the
following error from the web server
[Thu Oct 14 16:53:23 1999] HTTPd: malformed header from script
/usr/local/http/cgi-bin/mapserv3.22
[Thu Oct 14 16:53:23 1999] HTTPd: send aborted for 161.143.17.153, URL:
I have version 3.1 working fine.
my ini file is as follows
# Where are fonts and symbols files located
SYMBOL_PATH=/data4/WWW/mapserver/symbols
# Absolute path to writable directory where images are to be written. This
# directory needs to be:
# (1) writable by the user httpd is running as
# (2) accessible via the web
IMAGE_PATH=/data4/WWW/tmp
# Path relative to document root of the web server for the writeable
directory.
IMAGE_VIRTUAL_PATH=tmp
# Contact information provided if errors occur.
CONTACT_EMAIL=ross.searle at dnr.qld.gov.au
# Where are the log files to be created. Comment out if you don't want them.
# You must create the directory and make it writable by the user the web
server
# runs as. Alternatively, create a file called "access.log" there and change
# ownership or permissions accordingly.
LOG_PATH=/data4/WWW/mapserver
# File extention of template html files. Should be a regular expression.
This
# usually doesn't need to be changed.
#TEMPLATE_EXTENSION=\.html
# File extention of map files. Should be a regular expression. This usually
# doesn't need to be changed.
#MAP_EXTENSION=\.map
Ross Searle
Natural Resource Information Management Officer
Department of Natural Resources
PO Box 1143
Bundaberg QLD 4670. Australia
Ph : 0741 537 888 Fax : 0741 537 823
