Colr look up table
Stephen Lime
steve.lime at dnr.state.mn.us
Thu Oct 14 11:10:57 PDT 1999
I assume you're refering to lookup tables based on some attribute value.
Color tables, symbol tables etc. are now handled as classes. Like the old color
table each class has an (optional) expression associated with it. Instead of just
being able to control color, with classes you can control size, color, outlinecolor,
labels and so on... Here's an example with 2 classes :
# what item to I want to classify on
CLASSITEM foo
# now the class definitions
CLASS
NAME class1
EXPRESSION "0" # note: this is a regular expression
COLOR 255 0 0
END
CLASS
NAME class2
EXPRESSION "1"
COLOR 0 0 255
END
Assuming item "foo" contains either 0 or 1, 0's would be drawn in red and 1's
in green. Class names are used for legend building, ommit them if you don't
want a particular class to show up in a legend. Features that don't match any
class expression are not drawn. If all features are to be drawn the same, then
define only 1 class with NO expression defined.
Classes are a simple way to create thematic maps based on regular expressions.
Steve
Stephen Lime
Internet Applications Analyst
MIS Bureau - MN DNR
(651) 297-2937
>>> "Paul G. Allen" <pgallen at randomlogic.com> 10/13 4:46 PM >>>
On the ForNet site I was reading some old MapServer documentation (v2.3) about
making a color table. Does the latest version of MapServer support this? I have
a file as outlined in the afore mentioned documentation and I have used the old
printcolors utility to create a GIF image of it. Now I'm wondering if/how I can
use the color file.
Thanks,
PGA
More information about the MapServer-users
