Query template file question
Jim T. Bowen (GAIA Consultants Inc.)
bowenj at gaiaenv.com
Fri Oct 29 11:43:10 EDT 1999
Cheers Brent. We are running 3.219b...never thought of checking the ini
(still have to get use to that feature!). I will give it a try later
today.
Jim
Brent Fraser wrote:
> Jim,
> I'm not sure what version of MapServer you're running, but if
> it's recent, have a look at the mapserv.ini file. It has an entry
> for setting the template extension:
> # File extention of template html files. Should be a regular expression.
> This
> # usually doesn't need to be changed.
> TEMPLATE_EXTENSION=\.html$
> I'm not sure if this will solve your problem though. If it doesn't,
> perhaps you could explain the flow of control between mapserver
> and PHP3 in more detail.
> Brent Fraser
> ----- Original Message -----
> From: Jim T. Bowen (GAIA Consultants Inc.) <bowenj at gaiaenv.com>
> To: MapServer <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, October 29, 1999 8:40 AM
> Subject: Query template file question
> > Hi all,
> > Probably a question for Steve, but perhaps someone else can help.
> > We are using PHP3 to access database information via our site. We are
> > also using PHP3 to link MapServer with PostgreSQL. The links are
> > rudimentary at this point, but show potential. At this point, all we
> > have in place is: Query function passes a unique id to PHP3 script that
> > then performs a query on PostgreSQL and dynamically creates html
> > output.
> > My question lies in the 'query template' identified in the MapServer map
> > file. The docs indicate that output can be passed to an URL or template
> > file. I cannot find docs or eg. relating to passing the query info. to
> > an URL. I would like to do this because MapServer does not recognise a
> > .PHP3 extension as a valid html template file. I think I found where I
> > would need to change this in the source, but perhaps someone could shed
> > some light on this (C is not my forte). I do not want to dick with my
> > apache settings...I believe source change would be fastest and least
> > intrusive to our web server. Currently, I have a temporary html
> > template that grabs MapServer variables, and passes them via the URL
> > string, using an http-equiv redirect. (yuck)
> > I would have included the URL for the site, but the information is
> > confidential (client request...sorry). Thanks in advance.
> > Cheers,
> > Jim
> > ___________________________________ GGG G AAA III AAA
> > | Jim T. Bowen, M.Sc., President | G GG A I A
> > | | G G A A I A A
> > |Suite 306, 822-11th Ave. S.W. | G G A A I A A
> > |Calgary, Alberta, Canada T2R 0E5 | G A A I A A
> > |Ph: 403-571-7213 Fax: 403-571-7211| G GGGG A A I A A
> > |_______bowenj at gaiaenv.com__________| G G AAAAA I AAAAA
> > ICQ: 15567315 G G A A I A A
> > http://www.gaiaenv.com G G A A I A A
> > GGGG AAA AAA III AAA AAA
