[beginner] Why does it look like a map of Arctic
Snowfields?
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Sep 15 15:39:55 EDT 1999
Boy, I need to setup an FAQ for blank maps. If you've got blank images
and not broken images then there are only a couple of (common) possiblities. (The
mapfile isn't much help without an example calling URL)
- extents aren't right
- path to data isn't correct
- layers aren't turned on in the form/url
There are a couple of other possiblities related to multiple class definitions but no
classitem defined, but that doesn't look to be the case here. Send me a URL or
a form and I'll try to help some more.
Steve
Stephen Lime
Internet Applications Analyst
MIS Bureau - MN DNR
(651) 297-2937
>>> Jason Domina <jdomina at ystone.mt.gov> 09/15 1:40 PM >>>
howdy,
Normally I am loathe to issue a cry for help on matters that are trivial to
those who have RTFM :) However, time has squeezed me into a corner that I
cannot wriggle out of. I am not an GIS analyst, so much of this is still very
confusing. I am a web developer working for a local county government in
Billings, MT USA. We've been using ESRI's MapObjects and Internet Map Server
to develop a web based interface to the county's GIS information on Windows
NT(IIS4). The tirade of expletives this software combination has caused me to
expell isn't worth repeating, but needless to say, these products have
occasioned me to explore alternatives. A quick search on Freshmeat.net brought
me to MapServer and having viewed the speed and stability of the demo site, I
quickly became enamored.
I can get the demo setup and running correctly on my test machine which is
currently running Caldera OpenLinux 2.3 and Apache 1.3.9. However, when I try
to use some of our shapefiles I get nothing but an Arctic Snowfield. My map is
just a big, ol' white square. I hope it is not too crass, but below you will
find a copy of my ystone.map file. What am I doing wrong?
Thank you,
Jason Domina
Yellowstone County IS Internet Specialist
-------------begin ystone.map----------------------------
# Start of map file
NAME ystone
STATUS ON
SIZE 600 600
SHADESET symbols/shade.sym
MARKERSET symbols/marker.sym
LINESET symbols/line.sym
EXTENT 2106685.23181818 443164.375 2492152.01818182 823786.875
UNITS FEET
SHAPEPATH /home/httpd/html/mapdev/data
IMAGECOLOR 255 255 255
LABELOVERLAP FALSE
# Start of web interface definition
WEB
HEADER demo_header.html
TEMPLATE demo.html
MINSCALE 1000
MAXSCALE 1550000
END
# Start of reference map
REFERENCE
IMAGE graphics/reference_base.gif
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS MILES
INTERVALS 5
STATUS ON
END
# Start of layer definitions
LAYER
NAME Sections
TYPE POLYGON
STATUS ON
DATA /home/httpd/html/mapdev/data/sections
CLASS
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 248 248 95
END
END # Layer
LAYER
NAME Townships
TYPE POLYGON
STATUS ON
DATA /home/httpd/html/mapdev/data/towna
CLASS
SYMBOL 0
OUTLINECOLOR 0 0 102
COLOR 255 255 240
END
END # Layer
LAYER
NAME primary_roads
TYPE LINE
STATUS ON
DATA /home/httpd/html/mapdev/data/Y_ROADS
SYMBOLSCALE 24000
CLASS
NAME "Roads"
COLOR 128 128 128
SYMBOL 13
SIZE 3
MAXSIZE 5
END
END # Layer
END # Map File
