Brian Fischer
bfischer at usgs.gov
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
----- Forwarded by Brian C Fischer/WRD/USGS/DOI on 04/10/00 12:01 PM -----
                    Brian C
                    Fischer              To:     "Grzegorz Myrda" <mapadm at polsl.gliwice.pl>
                                         cc:
                    04/10/00 11:56       Subject:     Re: Error compiling mapserv3.3.010 for NT(Document link: Brian C
                    AM                   Fischer)
Grzegorz,
Thanks,  adding that semicolon fixed the problem and mapserver compiled
fine after that.
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
                    "Grzegorz Myrda"
                    <mapadm at polsl.gliwice.pl>            To:     mapserver-users at lists.gis.umn.edu
                    Sent by:                             cc:
                    owner-mapserver-users at lists.g        Subject:     Re: Error compiling mapserv3.3.010 for NT
                    is.umn.edu
                    04/08/00 05:37 AM
It's because of lack of semicolon after "default:" phrase ("CASE"
syntax in MS VC is different than in gcc or other). I had the same
error.
GM
Subject:                  Error compiling mapserv3.3.010 for NT
Date sent:                Fri, 7 Apr 2000 13:38:49 -0500
> Has anyone got mapserv3.3.010 compiled for the NT?  I am getting an error
> when I try to compile it in Visual C++ 6.0.   It gets to the maplegend.c
> file and bombs out with   a syntax error.  Version 3.3.009 compiled just
> fine with the same steps.  I am trying to compile it with libtiff and
> freetype.  I know Steve mentioned something about proj.4.  Is this why it
> is not compiling?
> Thanks,
> Brian Fischer
> USGS WRD
> 2280 Woodale Dr.
> Mounds View, MN
> (612) 783-3133
