Enable/disable a group of layers (workaround)
Berend Veldkamp
berend.veldkamp at aris.nl
Fri Apr 21 10:43:48 EDT 2000
OK, I found a workaround myself, using JavaScript:
<SCRIPT LANGUAGE="JavaScript"><!--
function CreateCheckBox (layername)
theLayers = "[layers]";
if ((theLayers.length > 0) && (theLayers.indexOf (layername) > -1))
theResult = " checked";
else
theResult = " ";
theResult = "<INPUT type=checkbox name=layer value=" + layername +
theResult + "> ";
document.write (theResult);
//--></SCRIPT>
and in my HTML code:
CreateCheckBox ("allroads");
//--></SCRIPT>
All Roads<BR>
Still, there must be a better way...
Berend
Berend Veldkamp wrote:
> Here's a question concerning groups of layers.
> What I'm trying to do, is to enable/disable a group of layers with one
> checkbox. When I do this with a separate layers, there's no problem,
> this works:
> <INPUT type="checkbox" name="layer" value="road1" [road1_check]>Minor
> Roads<BR>
> <INPUT type="checkbox" name="layer" value="road2"
> [road2_check]>Highway<BR>
> <INPUT type="checkbox" name="layer" value="road3" [road3_check]>Other
> Roads<BR>
> When I group multiple layers in a group (in my .map file), it works as
> well, but the checkbox is always unchecked after the map is drawn.
> <INPUT type="checkbox" name="layer" value="allroads"
> [allroads_check]>Roads<BR>
> Any ideas, anyone?
> TIA, Berend
