Enable/disable a group of layers (workaround)
Stephen Lime
steve.lime at dnr.state.mn.us
Fri Apr 21 16:54:51 EDT 2000
This not working is an oversight in the source. It'll be fixed in the next release...
Groups are usefull when using URL base map file mods or when in mapscript.
Otherwise a unique layer name is NOT neccessary. So you could name all
that layers 'roads' and dump the group attribute for now and the checkbox
should be sticky as planned.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Berend Veldkamp <berend.veldkamp at aris.nl> 04/21/00 09:43AM >>>
OK, I found a workaround myself, using JavaScript:
<SCRIPT LANGUAGE="JavaScript"><!--
function CreateCheckBox (layername)
theLayers = "[layers]";
if ((theLayers.length > 0) && (theLayers.indexOf (layername) > -1))
theResult = " checked";
else
theResult = " ";
theResult = "<INPUT type=checkbox name=layer value=" + layername +
theResult + "> ";
document.write (theResult);
//--></SCRIPT>
and in my HTML code:
CreateCheckBox ("allroads");
//--></SCRIPT>
All Roads<BR>
Still, there must be a better way...
Berend
Berend Veldkamp wrote:
> Here's a question concerning groups of layers.
> What I'm trying to do, is to enable/disable a group of layers with one
> checkbox. When I do this with a separate layers, there's no problem,
> this works:
> <INPUT type="checkbox" name="layer" value="road1" [road1_check]>Minor
> Roads<BR>
> <INPUT type="checkbox" name="layer" value="road2"
> [road2_check]>Highway<BR>
> <INPUT type="checkbox" name="layer" value="road3" [road3_check]>Other
> Roads<BR>
> When I group multiple layers in a group (in my .map file), it works as
> well, but the checkbox is always unchecked after the map is drawn.
> <INPUT type="checkbox" name="layer" value="allroads"
> [allroads_check]>Roads<BR>
> Any ideas, anyone?
> TIA, Berend
