Using geographic data in the southern hemisphere
    Anton Coetzee
    anton.coetzee at vip.co.za
    Tue Aug  1 13:39:14 PDT 2000
Hi
I'm using mapserver (3.3.010) on Southern Hemisphere shapefiles (Gauteng
area) with no problem. I'm *not* using proj at all, so maybe that is an
issue?
As an example, here's the extent from one of my maps:
units dd
extent 28.05 -26.15 28.12 -26.19
So I can answer #1 - yes, mapserver *does* work OK with Southern Hemisphere
data.
Sorry I can't be of help with the other stuff.
Anton Coetzee
On Tue, 1 Aug 2000, Tim and Marcelle Sutton wrote:
> The data is in the southern hemisphere (ie. north/south coordinates are
> negative
> numbers in decimal degrees).
> 1) Does mapserver support southern hemispher geographic data?
More information about the MapServer-users
