TrueType font support with PHP 3.0.15 on RH 6.2 ?
Doyon, Jean-Francois
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Thu Aug 17 13:58:02 EDT 2000
Goodday,
Has any one successfully used the PHP module with FreeType support ?
Mine seems to be bombing when I switch to true type fonts ...The exact
same mapfile works fine with Bitmap fonts ...
Do I need some special FreeType support built into PHP ?
I'm just using the standard RPM's ...
Here's the info on PHP/Mapscript :
MapScript Version 1.0.011 (Jun 28, 2000)
MapServer Version 3.3.011 (pre-release) -PROJ.4 -FreeType -TIFF -EPPL7 -JPEG
Although ... This was probably a nightly build ... could that be it ? Is the
latest
stable release as featureful as the nightly builds/CVS ? I remember I
switched to
using those because of some feature I wanted ... Anyways ...
Anybody have any ideas ?
Thanks,
