Setting up MapScript on NT
Brent Fraser bfraser at geoanalytic.com
Fri Aug 18 07:00:15 PDT 2000
I got as far as a mapscript DLL.  When attempting to
use it with Perl (ActivePerl ) I get "Error: Parse Exception"
from Perl.
I've found no solution to the problem.  I think it may be
related to DLL calling convention (how the values are
passed from the exe to the DLL).  The DLL might
not be using the one that the ActivePerl exe expects.
The answer may be to get the NT version of Swig to
produce an ActivePerl-friendly interface definition with
the correct calling convention.
This is just a guess.  Not too much doc on extending
Perl on NT using Swig...
Brent Fraser
GeoAnalytic Inc.
#300 , 700 - 4th Avenue SW Calgary, AB
Canada T2P 3J4
Tel:  (403)213-2700 Fax:  (403)213-2707
www.geoanalytic.com
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, August 15, 2000 4:52 PM
Subject: Setting up MapScript on NT
> Has anyone successfully managed to make MapScript work on NT. If so could
> you explain how you did it ?
> Regards
> Steven Hayes
More information about the MapServer-users mailing list
