FW: TrueType font support with PHP 3.0.15 on RH 6.2 ?
    Doyon, Jean-Francois
    Jean-Francois.Doyon at CCRS.NRCan.gc.ca
    Thu Aug 17 11:32:07 PDT 2000
In further to this posting, looks like there's a sig11 from apache (Or does
PHP run as a diffferent process ?) :
Here is the error_log content :
[Thu Aug 17 13:38:44 2000] [notice] child pid 14811 exit signal Segmentation
fault (11)
[Thu Aug 17 13:38:52 2000] [notice] child pid 19103 exit signal Segmentation
fault (11)
[Thu Aug 17 13:44:36 2000] [notice] child pid 14816 exit signal Segmentation
fault (11)
[Thu Aug 17 13:45:04 2000] [notice] child pid 14809 exit signal Segmentation
fault (11)
[Thu Aug 17 13:45:09 2000] [notice] child pid 20351 exit signal Segmentation
fault (11)
[Thu Aug 17 13:49:00 2000] [notice] child pid 18384 exit signal Segmentation
fault (11)
This bites, I really need the TTF support !
J.F.
> From: 	Doyon, Jean-Francois
> Sent: 	Thursday, August 17, 2000 1:58 PM
> To: 	mapserver-users at lists.gis.umn.edu
> Subject: 	TrueType font support with PHP 3.0.15 on RH 6.2 ?
> Goodday,
> Has any one successfully used the PHP module with FreeType support ?
> Mine seems to be bombing when I switch to true type fonts ...The exact
> same mapfile works fine with Bitmap fonts ...
> Do I need some special FreeType support built into PHP ?
> I'm just using the standard RPM's ...
> Here's the info on PHP/Mapscript :
> MapScript Version 1.0.011 (Jun 28, 2000)
> MapServer Version 3.3.011 (pre-release) -PROJ.4 -FreeType -TIFF -EPPL7
> -JPEG
> Although ... This was probably a nightly build ... could that be it ? Is
> the latest
> stable release as featureful as the nightly builds/CVS ? I remember I
> switched to
> using those because of some feature I wanted ... Anyways ...
> Anybody have any ideas ?
> Thanks,
More information about the MapServer-users
