TrueType font support with PHP 3.0.15 on RH 6.2 ?
    Daniel Morissette
    danmo at videotron.ca
    Fri Aug 18 09:31:35 PDT 2000
"Doyon, Jean-Francois" wrote:
> I'm trying to get the extent of a map (as set in the map file) into
> variables
> for manipulation, but am not having any luck.
> I've tried things like :
> $minx = $map->extent->minx;
> $minx = $map->extent(minx);
> $extent = $map->extent;
> echo $extent->minx
> and a few more ... but I never get anything returned ! (No errors though).
Assuming your Map Object is called "$map", then
	echo $map->extent->minx;
or
should both work... we use it a lot. So it must be something else that
you overlooked in your function.
BTW, $extent = $map->extent;
     echo $extent->minx;
should work too.
 Daniel Morissette                       danmo at videotron.ca
              http://pages.infinit.net/danmo/
  Don't put for tomorrow what you can do today, because if
      you enjoy it today you can do it again tomorrow.
More information about the MapServer-users
