diffs for .shp
ender at titan.lab.csuchico.edu
Fri Aug 18 09:56:39 EDT 2000
I made a little change to mapshape.c that allows you to use:
DATA whatever/shapefile.shp
in the mapfile, instead of these shapes just being ignored. I find that I
still do this, even though I've been using mapserver for several years
now.
Anyway, here's the diff file.
-Aaron
1166c1166,1167
< char *dbfFilename;
> int i;
> char * dbfFilename;
1195,1197c1196,1209
< dbfFilename = (char *)malloc(strlen(filename)+5);
< sprintf(dbfFilename, "%s.dbf", filename);
> dbfFilename = (char*)malloc(strlen(filename)+5);
> strcpy(dbfFilename, filename);
> /* clean off any extention the filename might have */
> for (i = strlen(dbfFilename) - 1;
> i > 0 && dbfFilename[i] != '.' && dbfFilename[i] != '/'
> && dbfFilename[i] != '\\';
> i-- ) {}
> if( dbfFilename[i] == '.' )
> dbfFilename[i] = '\0';
> strcat(dbfFilename, ".dbf");
(See attached file: mapshape.dif)
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000818/f387e285/mapshape.obj
