TrueType font support with PHP 3.0.15 on RH 6.2 ?
Daniel Morissette
danmo at videotron.ca
Fri Aug 18 10:03:15 EDT 2000
"Doyon, Jean-Francois" wrote:
> Goodday,
> Has any one successfully used the PHP module with FreeType support ?
> Mine seems to be bombing when I switch to true type fonts ...The exact
> same mapfile works fine with Bitmap fonts ...
> Do I need some special FreeType support built into PHP ?
> I'm just using the standard RPM's ...
Bonjour Jean-Francois,
I have php_mapscript.so displaying FreeType fonts on my RedHat 6.2
system. However I am not using the PHP that came with RH6.2... I had to
recompile my own because I needed the DBase module linked in.
And following your message I tried switching back to the original PHP
that came with RH6.2 and my application started crashing like yours as
soon as it tries to display TT Fonts.
A quick compare of the 2 phpinfo() outputs tells me that the PHP that
came with RH included FreeType support but my new one didn't. that
could explain the bug.
I can give you a copy of my new libphp3.so if you want... it should
solve your problem for now, until I have time to look into the real
source of the bug.
Later,
Daniel Morissette danmo at videotron.ca
http://pages.infinit.net/danmo/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
