TrueType font support with PHP 3.0.15 on RH 6.2 ?
Doyon, Jean-Francois
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Fri Aug 18 10:03:16 EDT 2000
Dan,
Much thanks for the offer, but I've figured it out ...
I've managed to compile a version of PHP that suits my needs and
works with proper TTf support ...
I did however HAVE to specify --without-ttf ...
So I'm ok for now ... this does seem strange though, good thing I don't
need it :)
Thanks for the help,
J.F.
> From: Daniel Morissette[SMTP:danmo at videotron.ca]
> Sent: Thursday, August 17, 2000 3:27 PM
> To: Doyon, Jean-Francois
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: TrueType font support with PHP 3.0.15 on RH 6.2 ?
> "Doyon, Jean-Francois" wrote:
> > Goodday,
> > Has any one successfully used the PHP module with FreeType support ?
> > Mine seems to be bombing when I switch to true type fonts ...The exact
> > same mapfile works fine with Bitmap fonts ...
> > Do I need some special FreeType support built into PHP ?
> > I'm just using the standard RPM's ...
> Bonjour Jean-Francois,
> I have php_mapscript.so displaying FreeType fonts on my RedHat 6.2
> system. However I am not using the PHP that came with RH6.2... I had to
> recompile my own because I needed the DBase module linked in.
> And following your message I tried switching back to the original PHP
> that came with RH6.2 and my application started crashing like yours as
> soon as it tries to display TT Fonts.
> A quick compare of the 2 phpinfo() outputs tells me that the PHP that
> came with RH included FreeType support but my new one didn't. that
> could explain the bug.
> I can give you a copy of my new libphp3.so if you want... it should
> solve your problem for now, until I have time to look into the real
> source of the bug.
> Later,
> Daniel Morissette danmo at videotron.ca
> http://pages.infinit.net/danmo/
> Don't put for tomorrow what you can do today, because if
> you enjoy it today you can do it again tomorrow.
